Brake lights ???1984 chevy 6.2 diesel pickup
fink1978
I just bought my first MV last month. (6.2 Chevy diesel pickup). The blinkers/ brake lights were not working. I replaced the bulbs and now the blinkers are working but the brake lights are not. I'm sure you guys know both lights function using the same bulb. What should be my next step in getting them to work?
ssgtwright-usmc
Hawaii
Check the stop relay switch on the break pedal and have someone press it down while someone looks at the tail lights.
If it works by holding it down, re-adjust the stop relay switch.
319
Lieutenant
57
Michigan
Check the fuse, check for corrosion in the fuse block, and another very important item to check is the ground strap/tab inside the lamp socket, check all of them. I had an issue recently where they looked good but were actually cracked and not making contact.Also, use a die-electric grease to prevent further corrosion.
