- 12,195
- 319
- 0
- gainesville, ga.
im posting this here even though i have a 5 t because theres more 2 1/2 t then 5s out there. i had a rear rubber brake line start to seep, at first i was going to just replace the bad one, i decided to replace all 5. boy im glad i did, the other rear was all wreather cracked, the left front was weather cracked and had a big cut init from the clamp riding wrong , the frame to fromt axle was wreather cracked, and had been rubbing on the diff. top, the right front had been replaced some time in the past. im posting this so EVERYBODY check there brake lines now and then, and if you replace one replace all, no matter what the cost its still cheaper than no brakes and somebody getting hurt. remember we are pushing a LOT of weight
