Stop and count and stop
I tried and couldn't do it. I can stop or I can count but counting and stopping at
the same time is just too much.
Sounds like I'll need help with this one Gunner.
I've watched the gauge go down....and up....but can't tell you how many times...or how many seconds I pushed the pedal to get that to happen, funny.
I can check it out next time I tour but it's not a fair scenario for the G749. It'd help to know what the 'end result' info is that you're looking for. I can static test it in the backyard once the rain stops...quack quack.
Stopping and pedal usage will be different for different folks because a real 'trucker of the day' will pay attention to lights most times and not use the brakes.
I pre-charge the pedal as a test long before I come to an intersection. (the little flash on the brake lights tells smart drivers the big truck ahead is slowing down)
Usually I'm coasting to time the light instead of stopping at it and the trani does the rest. I'll hover on the pedal so I'm ready if I need it but the truck mostly stops on it's own with a little pedal application at the end, if I didn't time the light properly.
If someone is racing to the red light .......every time .....and stompin' on the brakes hard....to a complete jerk stop, then doin' it again....their 'pedal usage' and burn of available compressed air will be different then mine. Most attentive drivers with big weight will tell ya' they time every light. If the brakes are needed, they feather them on and off, , to 'cool' the drums/rotors as they come to a stop.
I may need to remove the cover and watch my diaphragm operated plunger activate the trigger that keeps my inlet valves off their seat, stopping compression when pressure reaches 100psi.
Soooo, if the big question is how many times do I push my pedal to get the "air pressure" in my system low enough to have my governor kick in.....assuming I followed pages 451 and on....here.....[FONT=Arial, Helvetica, sans-serif]
TM 9-8024 (part 3 of 4) and have my top pressure at 100psi and governed to kick on at 75psi......... I can get you an answer.[/FONT]
