Vinnie1511
- 4
- 3
- New Jersey
I recently purchased a 1970 m35a2, I was going through the braking system and I replaced the master cylinder. After that I bled from the m/c to the air pack and then bled each wheel. After completing the bleeding process when you go to press the brake pedal it’s stiff as a rock and I hardly have any braking power. I noticed when I press the brake pedal down (hard) the air pack kicks the air on and then the pedal pushed back torwards me. I oiled the air pack also with no help? Any idea what could cause the pedal to be so stiff and to jump back at me once the air pac engages? Thanks for any input!
