chillydog
- 1
- 0
- Scranton, Pa.
On CUCV's and other military vehicles where the military used silicone brake fluid, can you just replace a brake system component-wheel cylinder, caliper, master cylinder, brake hoses-with a factory new unit, bleed it and go on, or, do you have to disassemble the new component, wash the factory DOT 3 assembly fluid off using alcohol, and reassemble the component with silicone brake fluid? In light of the cautions against mixing DOT 3(conventional) and DOT59 silicone) that you hear, in this case-- is it really a consideration ?
What do you guys do?
Thanks!
Thanks!
