Brake spring
Thompsona3
Shelby twp MI
Hi I'm replacing a caliper on my m1028. Anyone know any tricks for getting the spring back in? I know it goes under the bracket but I'm havering trouble getting it to go on any advice would be helpful thanks.
cucvrus
10,225
Jonestown Pennsylvania
Put the caliper back up in there at the top. And use a screwdriver or a pry bar to hold it up in place. Put some grease on the bar and spring bar and tap it into place. You do need that it will be loose without the spring tightening bar. Align the bottom bar with the allen bolt hole and adjust from there.
