brake switch
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
I got to looking at why my brake lights don't work. It looks like the switch on my master cylinder is bad. Do we have a part # or know who stocks those? I guess I will call Saturn on Monday.
Boatcarpenter
17
Marlborough, NH
On a brake light switch that was bad on my deuce the numbers read as follows;
Fasco Industries No73321
Ord No7064588
Don't know if those #'s will help or not.
BC
gimpyrobb
27,785
749
Cincy Ohio
Jeff you are correct! My current setup is the "before" pic. Any reason to not look for a replacement? I think that would be easier at a supply house than the upgrade.
ken
25
Houston Texas
I got tired of those switches failing. So i took a piece of angle iron and clamped it to the brake pedal arm. I drilled a hole in the angle and put a brake switch for a 82 chevy truck in it. Then i wired 2 blade connectors to 2 male pin connectors and plugged them in. The switch is now held aginst the bottom of the floorboard. Now when i step on the pedal the switch is actavated by from taking it away from the floor. So the lights come on as soon as i touch the pedal. Not when i push hard enough to start braking. I can get tailgators to back off with out slowing down. The chevy switch was $5 and much easier to find.
bottleworks
Central NC
Saturn has the NSN 2530-01-105-5025 upgrade kit. Listed @ $38.50. The upgrade makes your truck have one less thing that could cause a hydraulic leak/failure.
1,176
Ken, could you post a picture or two of your brake switch modification? That sounds like an easy and reasonable fix for the hydraulic brake light switch replacement. Did you remove and plug the original switch? This also eliminates the possible leaking issue, like the upgrade kit does.
