chuck500cc
- 2
- 0
- DFW Area
So if I see the "brake" light on the dash of an M35 there is a good chance it is a later model truck with split brake system...right?
Chuck XD Fan
Chuck XD Fan
I thought the "air pressure warning light" was just a red lens covering the lamp, Does it say "BRAKE"?emmado22 said:Yes and no.
The later model M35A2C's have the dual brakes, and that has the BRAKE light in the middle of the dash.
There is also a retrofit kit for a "low air pressure warning light kit" that installs the same BRAKE light in the same place on the dash, and that kit can be put on ANY M35A2.
Best way to check is get under the truck and look for the 2nd airpack. 2nd airpack = dual brakes
