Bjorn, Help!!! I was cleaning the sub-master cylinder portion of the unit and you guessed it, one cup, a double coil spring retainer cup, (for lack of anything better to call it), and two long coil springs, one inside the other took off accross the room before I could grab them. As they flew by I tried to see what way everything was facing but it didn't work so good. I have posted a picture the way I think they should go. The rubber cup on the right I took out so I know that one is correct. The plunger body I took out also so I know that is correct. The second cup from the right I believe is correct also as I had seen the flat side of it when I looked in the bore after I had taken the first two items out. Logically, the concave side of the spring retainer cup has to face the springs and the smooth side sits in the rubber cup. Does that seem proper from any diagrams that you have. My big question is whether or not there are parts I didn't find after their hasty exit from the cylinder. How does this all look to you?
Thank you very, very much for any input.
