Brakes - Noise coming from under hood - airline?
NorthWoodsDuce
Wisconsin
I've searched and can't find anything on this, maybe airpack rebuild? When I shut the truck off I can hear a "gurgling/bubbling" noise coming from under the hood. When I checked to see where it was coming from, I found a copper tube running up from the passenger side framerail along the back side of the firewall. It has a fitting on the end of it, but nothing connected to it. It sounds like air is leaking out of it, when I push the brake pedal with the truck off it pulls brake fluid (i think brake fluid) out of that tube and dumps it onto my exaust pipe below. Any ideas? Also curious what the fitting ontop of the brake fuild resivour is for?
And I did look at the sticky on airpack rebuild and at my TM's, but still a little confused! :)
Thanks!
acetomatoco
That is your Master Cylinder fording vent on the top of the MC. If it is blocked your system will be constipated.
NorthWoodsDuce
Wisconsin
So just disconnect the lines and clean them out? Just curious why brakefluid is coming out of that line? It sounds as if air is leaking inside the airpack also..? I can post pic if that would be helpful to ensure i'm explaining it right. Thanks!
acetomatoco
Air pak may have a fault also, I was just addressing the MC cover vent. Lots of folks just put a differential vent in the hole in the MC cover if they plan on no extended fording...
WillWagner
2,584
Monrovia, Ca.
If it is pumping BF out the blowby tube, that means the M/C vent is still plumbed to the BB tube. There is a problem. Nothing that repairing the air pak won't fix.
NorthWoodsDuce
Wisconsin
BB Tube? The same tube that branches off to the top of the master cylinder goes to another brake part (can't remember exactly where it goes, and not close to my truck right now) Is the brake fluid probably coming from the other part? (maybe the airpack..) or from the top of the master cylinder?
