dabtl
- 7
- 38
- Denton, Texas
The brakes failed, leaking cylinder on the driver's side front rear. To the shop.
Rear axle, passenger side, leaking brake cylinder, slick shoes, no braking apparently.
Front rear axle, passenger side, leaking seal, minimal brake. Front rear axle, passenger side, leaking wheel cylinder as expected. Brake failed, but otherwise it had been in good condition.
We move to the front axle on Monday. I hope it is OK, but then everything is being replaced.
By Wednesday it should have a completely new set of seals, a new brake system including shoes, wheel cylinders, air pack, master cylinder and new flex hoses.
You cannot be too careful.
