Brakes REALLY touchy
springbok
Wilmington Delaware
My 998 has really really touchy brakes, it only takes 1/2" tops for them to engage.
So far I have yet to see a solution. My major issue is that the brake lights do not come on.
The switch is adjusted back as far as it can be..
Anyone have this issue, a solution ?
MaverickH1
Roanoke, VA
Mine was similar. In order to change it I ended up having to add washers between the switch and the mounting flange to essentially place the switch further from the brake pedal's linkage point. Doing this brought it back to the window where you could adjust it to be in and out.
Even after making it perfect, the next week it had gone out of adjustment and I only got brake lights if the brakes were essentially locked. I adjusted it again last night and it seems to be doing okay. I don't know why it went out of adjustment. All bolts were still tight, but the linkage does have a tendency to loosen up with those flaky push washers that hold it, so it may have gotten loose because of that.
I had just replaced this brake switch due to the last one failing, and it may exhibit the same symptom's you're talking about to a larger degree. I had a thread on it in this forum. If it passes continuity and voltage testing and still fails to send amperage to the bulbs but it does send enough amperage if you manipulate it just right, replace the switch.
