Braking kills the lights
Jim832904
Towanda Pennsylvania USA
Touch the brake pedal and all of the lights go out. The breaker resets and lights come on. Will repeat consistently. Have looked for bared wires , have removed and tried without brake light bulbs. Cant find a cause. Everything I can see looks ok. What can I try next? M929-A2.
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
Does it do it with the turn signals on? Like throws the breaker, If not look for the brake light switch to be shorted out or the wires to and from it.
Drivers side inner frame well just to the rear of the fuel tank
https://youtu.be/ggxfblpk56k
Sent from my SM-G935P using Tapatalk
simp5782
9,329
Mason, TN
Thanks! Unplugged the switch and lights are staying on. !00% offroad use so it's fixed.
Good deal.
Switch is available thru napa for not much. Found in the parts spreadsheet in the 5 ton stickies
