Brights lights....
combatmech
Carrollton, Texas
Howdy all,
The last time I got the truck worked on, they found a headlight that wouldnt go bright. The headlights are old so I changed both. When I checked them...same thing....they run normal, but when you click the brights on, the LH headlight goes dim, the RH light goes bright.
Side note....Soon after I bought the truck, I had a relay of some kind fall out from under the dash.
Could this be the problem??I still have the relay, and looking through the CUCV manual, I still have no idea where it goes.
combatmech
Carrollton, Texas
Thanks guys...I'll try that. The connector didnt look that bad when I changed the lights...
The relay is a 5 pin bosch p/n 0 332 204 151 12v 20/30amp
