honda
- -1
- 6
- Southern Arizona
Guys, gonna need a little help here.
Broke an axle in the AZ outback. Way outback. Jeep trail 30 miles from closest road. No hope of assisted recovery short of a skycrane. Must be repaired in place. Unable to remove c-clip. 3.73 setup. No lift. Too much torque over rocks on a very steep slope. Axle, driver side, is twisted off like a twizzler about 10 inches from the spider gear.
Fortunately, unit is on level terrain. Lucky break.
Only hope is to replace entire pumpkin, sort out the mess back in the garage and head towards a stronger rear differential solution. But for the moment, I gotta get the unit back to civilization. Going in this week with a Razor, replacement pumpkin with axles etc.. Headed for a pumpkin swap out, in that the broken axle seems to be bound up inside the housing.
Would greatly appreciate a little assistance with the following:
About how much does an entire pumpkin weigh, absent the brake drums?
Takes about 4 hours to reach the unit over extraordinarily rough trail, so I really need to take everything the first time. Weight distribution and loading balance on a Razor is very important due to rough trail conditions.
If this were you, what would you take?
Thank-you, any and all ideas are gratefully appreciated.
