Broken Sprag
Scoobie-Steve
Bangor/PA
Today I tried pulling a large stump out and found my front wheels dont engage. What should I do, Is the sprag worth rebuilding. Air shifts seem to be far a few between. Help me out.
gringeltaube
Staff Member
2,389
Montevideo/Uruguay
Broken??? What if it only needs some maintenance/adjustment of the linkage between tranny and T-case? See TM 9-2520-246-34, 4-28 d. Sprag Unit Test. Jack up one front tire to test it.
Gerhard
davemccoull
Nelson Lancs U.K.
Broken sprag
I had same fault when i first got my truck. I pulled the transfer box out, removed the front cover were the sprag clutches are, they were gummed up with old oil, i took them out , washed them in parrafin, stoned any small burrs of them, put it all back together and its worked fine since.
You could try draining oil and giving case agood wash out with degreaser, it might do the trick. It would save pulling box out.
I don,t know if the front cover will come off with the box in place, but as Gerhard says check the linkage first, jack a front wheel upand push operating arm in witha bar, you should only be able to turn wheel one way.Best of luck. I just swapped my sprag box for air shift last week.
Best of luck
Scoobie-Steve
Bangor/PA
My front wheels for sure didnt engage in frontwards or reverse. I will try adjusting it. and maybe an oil change. Can the sprag assembly be worked on without pulling the t-case?
JasonS
131
Eastern SD
The front case containing the sprag unit can be removed with the transfer case in the truck. There are two sets of sprag clutches; one for forward, one for reverse. The forward sprag will be worn much more than the reverse. It will be obvious when you take it apart. The procedures are well documented in TM9-8022. It would be best if you fully understood how this system works before taking it apart (maybe unnecessarily). New/ rebuilt sprag units are available from the vendors. Be careful, though. The "new" sprag unit that I purchased was not new or rebuilt. I ended up installing a REB kit which replaces the sprag clutch and front drive gears.
davemccoull
Nelson Lancs U.K.
Broken sprag
Just another thought, i presume the front propshaft is turning when you have a wheel jacked up and turn it? I wondered if somebody had maybe bored the drive flanges out on the front hubs, to let them freewheel!. Let me know how you go on.
