Broken starter bolts
jdeoliveira74
wilmington nc
Ok so i broke a starter bolt... drilled out got new bolts problem solved! My starter was replaced with a 12v one and they didn t put the front starter bracket on. i have purchased the piece but with no bolts. Does anyone know the size of the bolts? that attach to the bracket and starter?
thanks
rickf
1,638
Pemberton, N.J.
If you are going to run that 12 volt starter on 24 volts then stock up on flywheels! It will fail to engage 60% of the time and chew the teeth right off. The starter should have a stud of of the back and the truck is either 10mX1.25 or 3/8x16. I don't remember if they are metric or not, I believe they are.
Rick
Warthog
232
OKC, OK
The starter itself should have a mounting stud that is part of the long housing bolt. If it doesn't you will have to buy one from a starter rebuild shop.
The bolt that attaches the bracket to the block is a metric bolt. Should be available at you local hardware store (ie ACE)
It is a "M8 x 1.25 x 20"
*** EDIT ****
Which type of starter do you have? As the Gear Reduction starter is different
jdeoliveira74
wilmington nc
i dont know what kind of starter i have to be honest.... i have the truck 2.5 weeks and have been tinkering since i got it. Replaced rear main seal oil pan gasket. transmission filter and gasket. fixed vacuum for transmission. learning as i go.
How do you tell them apart?
Warthog
232
OKC, OK
The newer style Gear Reduction is on the left. The housing is smaller.
The older sytle Direct Drive is on the right. It is bigger in size.
Also the support bracket is different. You have to know which starter you have in order to know which bracket you need.
73m819
325
gainesville, ga.
What a difference in this thread then another cucv thread, ATTITUDE sure makes a difference :beer:
