Broken Wheel Stud
73m819
319
gainesville, ga.
looking at the pic, the stud had a OLD crack, no wonder it broke
Jake0147
Panton, VT
Hard to proove, big impact guns may have played a roll, but when you flat out "twist one off", it does not look like that. It looks an awful lot like ones that shear after (not during) a episode with wheel nuts coming loose, but not off. Probably sometime in the past. Probably not with the wheel that's on it now. Consider knocking in the whole set. Were it mine I would no longer consider any of the six to be trustworthy.
dave wagner
garland ne
might have been from being over loaded and turning sharp on dry pavement our fire dept had a deuce that had that happen to it more than once because of over loading [back tire only]
rosco
Delta Junction, Alaska
Jake nailed it. A loose wheel will do that - they get fatigued, then fail sometime down the road. I have a lot of my own stuff, and am very careful about somebody using a big air wrench. They can do a lot of damage, that is invisible for some time. I watch them like a hawk, when they are useing the big guns.
flyxpl
9
Chatham IL
One of my trucks had some lug nuts that were not tight , and one already broke . When I went to tighten them up another snapped off before it was very tight . You need to replace all the studs on that hub .
JCKnife
46
Kentucky
I'm doing the front axle boots, and finding some of my studs are pretty rusty. Are replacements readily available?
hoop
14
va
Jake,
Your post makes sense. I am the guilty party here.....loose nuts about 6 months ago.
I will do a replacement.
Thanks.
SCSG-G4
PSVB 3003
3,322
Lexington, South Carolina
Replacements are available - OD Iron, Saturn, Memphis, Erik's, large truck stops, heavy truck dealers and heavy truck repair (including truck tire) shops.
73m819
319
gainesville, ga.
When you replace, BESURE to get the right thread rotation, left or right hand
