Brush guard bolts
riderdan
20
Central Kansas
Still going over the truck and finding little things... like the hood hinge pins that didn't have cotter pins in them.
Checking the brush guard (original style) I noticed that the bolts holding it on seem under sized. There's about 1/4" of wiggle and the retaining pins are hard to get in/out because the holes on the mount and guard don't line up quite right.
I realize part of this could be wear, but could someone confirm the size of the bolts that are supposed to be holding this on? I didn't find a TM for this that showed bolt size...
Action
1,563
East Tennessee
I have a newer brushguard. I think on the bolts that hold it on (pivot point), there is an aluminum sleeve that fits in the hole to keep the guard in the correct spot. Then, your thinner bolt would fit in the sleeve.
riderdan
20
Central Kansas
I did eventually find it in the TM, but it just shows the newer, tubular guard. Without sleeves. I'm going to go caliper the bolt and hole and see what I can come up with. I wonder if I could use a piece of bearing bronze tube to tighten things up...
Action
1,563
East Tennessee
My "sleeves". Were part of the kit. They are slightly longer than the thickness of the guard and mount. If you just use bolts snd tighten them down, it will be difficult to lower the brushguard.
CGregson
Sammamish/WA
I'm confused, TM 9-2320-280-24P-2, 437-1 is the first gen brush guard no? All very clear on what bolts to use? What bolt number do you think you have wrong?
CGregson
Sammamish/WA
I believe you're talking about your pivot which would be 3(bolt), 4(washer), 4(washer), 10(castle), 11(cotter pin). If loose, are you missing the washers? The bolt appears to be 5/8x18 x 2"
