Brush guard identification help
prtaick
Philadelphia/PA
Hi, New to the forum.
I've searched and looked over about 100 posts and exhausted my google searching. I am looking to ID the mounting for my brush guard and potentially locate an original one.
Here are 2 images of my front bumper. 20171220_155443.jpg20171220_155448.jpg. I don't even know if this is original.
It looks similar to the bent angle style guards, (like this one 1985-Military-Humvee-front.jpg, NOT MINE). However I have 2 tabs sticking out for the locking pin instead of 1.
Any help would be awesome.
Patrick
porkysplace
1,487
mid- michigan
prtaick
Philadelphia/PA
Bought it 2nd hand. I'm going to take it off and check for numbers. It didn't match anything I saw in the manuals so far.
Also going to ask the guy I got it from, but he didn't seem to be the type to add anything to the truck. It actually looks like he took some stuff off.
I'll update either way. I hate reading forum posts with dead ends.
tage
68
LOS ANGELES / CALIFORNIA
What year is yours? It's not the first time GP has let a "concept?/preproduction" truck get through the auctions.
But it's definitely home brew. Those welds are all cracked.
I agree with above. I'm leaning towards non brush guard too.
prtaick
Philadelphia/PA
Its a 1992 M998 Serial 130428.
@tage, Its not cracked welds you see. That cracking is the rust pushing the finish off. You can see better in these images. The welds look good, not robot welded good, but good.
Took them off and found no numbers. Called the guy I bought it from and he told me that he took delivery of it and "gave" it right to me. Looks like all he removed from the truck is the antenna mounts. I'm in manufacturing and if these were homemade I want to hire the guy that made them :p. These things look to have been stamped out not cut (you can sorta see the undercut and some markings from the blanking process, or that's what it seems to be).
I also noticed these back two bolts (center of the image) were missing. Not sure what should have been here and if it would have been part of what I'm looking for.
Side note. What would have been mounted here?
prtaick
Philadelphia/PA
I'll try again. Long story short
Contacted the seller and he told me its exactly as he got it from the auction. Couldn't imagine he would have any reason to line since I paid him cash. Lol
Brackets off and inspected. No part numbers to be found and the construction looks to be from production. You can just make out the undercut on the edges of the metal from the blanking process. If these were one off parts the guy took care and had some good equipment.
These frame bolts were also missing when I got it.
Tage,
Its not cracking welds you see, its actually the thick paint chipping and pushing up because of rust.
Still trying to research and ask around but no luck so far.
Side story. What would have been mounted here?
