- 728
- 6
- 18
- New Jersey
Who ties up flies? What do you do with them after you tie them up? I just smash them.That might be big enough to tie flies with....
That is so true. I have two vises on my workbench downstairs. A Wilton 8" and a smaller 4" Wilton. The smaller one gets used 98% of the time.After one gets over the chuckle of that, they might reconsider. That would be handy for a lot of things. I have a decent Yost vise on my slide out work bench in my SECM. I also have a tiny Wilton on the tailgate. I use the Wilton 25 times for every time I use the Yost.
This is only limited by your imagination. For the non fabricating crowd, Harbor Fright sells 2 different rating bolt on recievers. The expedition folks use the heck out of this design for everything from tables to grills to shower heads. Good stuff here. If you have a massive vise/vice, you may require a support leg/group.One of the most useful things I have seen for mounting a vice for use on a vehicle is to mount it to a plate welded to a piece of 2" square stock. Slides into a receiver hitch. This make one vise for multiple trucks. And you can weld a 2" hitch into the front bumper or anywhere else you need.
