Bumper re-stenciling - which TM?
tonidial
marion, il
Bumper re-stenciling - which TB/TO/TM?
2 years ago I stripped the paint off the front bumper and repainted it - I'm just now getting around to stenciling. I had taken measurements of the tan/sand background and spacing, but have since lost them (go figure).
Would any of you gents know which TM/TO/TB I should look at?
Truck is Army, 1972 AMG M35A2
I've notice that most modern looks don't have the stripe background, but a block format. I wanted to keep the stripe look.
Sorry if this has been covered before elsewhere - I'm waving the white-flag after 5 hours of searching and looking through the wrong TO and TMs.
CARNAC
The Envelope Please.
619
Corpus Christi, TX
I did a thread on this about my experience on bumper numbers. The truck maybe from the lowest responsible bidder but the bumper numbers are put on by the lowestprivate on extra duty as punishment for some infraction.
tonidial
marion, il
Yes, thanks. When I said stripes I probably should have said strip - meaning the background strip behind the numbers. Was this a stand for regular military or is this possibly a National Guard marking scheme? Assuming is was regular Army, would someone know which Manual/Order/Reg or bulletin to look at for the height and width of the sand/tan strip and the correct offset spacing of the number/letters.
mkcoen
381
Spring Branch, TX
I found this simply by using the search function at the top right of the page:
USAFSS-ColdWarrior
02-28-2012, 05:09
You will find the BUMPER NUMBER specs in this TM:
43-0209.pdf
To find it, click on this link (Or visit the RESOURCES TAB at the top of each SS WebPage)
http://www.steelsoldiers.com/deuce-tms/
(scroll down toward the bottom to find a link to that TM.)
The Bumper Number descriptive begins on page 8 of 407.
There are FOUR distict designators with specific locations and purposes.
Good luck.
CARNAC
619
Corpus Christi, TX
That I don't think is a specific measurement. I've seen rectangles like yours, 29th ID has ovals, some have entire bumper (top to bottom) painted from the cleaves outward.
tonidial
marion, il
Thanks - I speed combed that TM twice today before positing - I'll revisit it again, but I was looking for an exact diagram/roadmap of measurements/arrangements. I learned a lot about the specific designations via page 21.
tonidial
marion, il
Thanks - I think I'll just wing it then after studying the old photos.
Tow4
626
Orlando, FL
When I re-stenciled my trucks, I tried to match the style that was previously on the truck. All of them are different, so I didn't get too concerned with trying to match a specific TM.
Amer-team
32
Centralia/WA
There has to be something newer out there, but TB 43-0209, OCT 1976, which superseded TB 746-93-1, OCT 1964. These are color, marking, and camouflage Technical Bulletins.
Also OCT 2003 of Military Vehicles Magazine has a great article on the Vehicle Markings. Good luck.
bikeman
501
Ft. Bragg, NC
There's not a recent coloring TM. I was doing some research a few years ago when I was in, regarding the National Star. The TM that covered this was so old, it had actually expired (20 or 25 years IIRC). I notified the proponent agency, but nothing has been published since.
Amer-team
32
Centralia/WA
I know it isn't recent, but it is the only one I have and it could get someone on the path. I would like a newer version and will keep looking. The article in Mil. Veh. is a really good one.
tonidial
marion, il
Looks like someone went a bit wild with the tan background. You have a Field artillery truck.
The layer beneath shows Armored Cav - HQ 85 - When I took out at the front Bumper I tried to peel back the layers with a chemical stripper- trying to find the first numbering from the 70's- Unfortunately it was indecipherable - and wouldn't have looked right with 383 paint.
Amer-team
32
Centralia/WA
MtnSnow, thank you for sharing the painting manual.
I have used chemical strippers, wet dry sandpaper and my current favorite is 4 - 0 steel wool and water. But sometimes 4-0 and lacquer thinner works very well too.
