- 1,649
- 814
- 113
- Central NY
So... I decided to tackle the bent, twisted, cracked and much repaired (none too well) front bumper.
First, using 20 ton bottle jacks, under the rear bogey, press the major bends out......
Bumper resting on two 4x4s placed equidistant from the apex of the bend I'm trying to straighten.
Small steel plate, 1 inch square, under the blocking below the jack to focus the force near the flange. THis was to remove a twist in the bumper.
Stretched top flange, from previous bend, bumped up after bend was straightened.
After some hot shrinking, I managed to push all the steel back to where it came from.
Splits to top and bottom flanges on other end, probably previously repaired running through bolt holes.
Need to check if both 'wings' are at the same angle, probably not. Just see a tight, small kink next to the bend on the drivers side. Not going to try get that out.
Ground and opened the splits to allow the drivers side 'wing' of the bumper to be 'Come-a-long'd' back to a matching dimension to passenger side. Square tube clamped on the front of the top flange to measure set back of ends of bumper. Came out at about 7 1/2".
