Burning B20 in my M1009
rjinga
Monroe, GA
Hey everyone,
I promise I searched the existing threads and posts before I started this one, but I couldn't find the specific answers I was looking for. I just have a couple of questions:
1. Can you burn B20 in a M1009 6.2 liter diesel engine? I'm not interested in mixing it up in my backyard. I'd be buying it from a National Biodiesel Board retailer in my county.
2. He (the retailer) said the biodiesel is a solvent and I'd need to replace any rubber components in my fuel system.
a) Has anyone done that to their M1009? If so, what all is involved?
b) Is there a "kit" out there so I can be sure I'm replacing everything at one time?
rjinga
Monroe, GA
Well, I just read this off the National Biodiesel Board biodiesel useage checklist:
"In general, pure biodiesel [B100] will soften and degrade certain types of elastomers and natural rubber compounds over time. Using high percent blends can impact fuel system components (primarily fuel hoses and fuel pump seals), that contain elastomer compounds incompatible with biodiesel.... Blends of B20 or lower have not exhibited elastomer degradation and need no changes."
Third question: Is anyone burning B20 without swapping out their rubber components? If so, for how long and have you noticed any degradation?
mangus580
282
Western NY
I have run B100 numerous times in my 1009. you may have to watch some of the soft fuel lines over time. Depends on how old said lines are.
rjinga
Monroe, GA
I'm guessing they are original, so 26 years old?! Might be a good excuse for a change anyway. Does anyone know what that (fuel line replacement) would cost?
mangus580
282
Western NY
Properly made biodiesel is NOT corrosive....
The hardened components of the Mil-Spec IP in the CUCV trucks should stand up to biodiesel just fine.
Its been said that todays 'ultra low sulfur' diesel is just as harsh on IP's as biodiesel, if not harsher due to the lack of lubrication.
rjinga
Monroe, GA
I'm not trying to parse words, but my understanding is that the biodiesel (in higher ratios anyway) acts as a solvent to soften and dissolve, no as a corroding agent. If that is what you mean, then just ignore this paragraph.
Hey, If you can burn B20 as is with not system changes, I'll be at the retailer place tomorrow filling up!
mangus580
282
Western NY
I doubt you will notice anything by running B20 for some time. Your biggest concern will be the return lines for the injectors, the return caps, and the flex hose right by the IP.
You can change them all up front for about $50 - or just change them as problems arise...
rjinga
Monroe, GA
I'm liking this more and more. Mangus580, do you have personal experience with biodiesel in your vehicles?
rjinga
Monroe, GA
Well, considering I work at a commercial biodiesel plant...
:beer:
We ran B100 in our 6.5's all summer, up until mid/late november
Well ok, but other than that... ;) So, would you run B20 from a National Biodiesel Board retailer in your '85 M1009 without modifications?
