burnt fusable link?
nighttrain2006
park forest ill
ok i have a 86 m1009. went to start it yesterday and nothing. tryed it again and burnt the fuseable link on the 24v (pass) side. it the wire on the forth terminal. i think this is the wire that goes to the starter relay.
Also after this happened the gen 2 light on the dash is no longer working?
I have the glow plug control card bypassed.
TOday i reconnected the fuseable link , and put a new starter relay in. Went to start it and burnt the link again. i just put in a brand new starter two weeks ago. truck is still 24volts.
Is the starter bad? OR could a bad alt cause this problem? Looked for loose and or fryed wires could not find any. Also is gen 2 on the driver or pass side? thank you
dependable
187
Tisbury, Massachusetts
first guess from far away, the #2 alt needs its ground isolated. 2nd, check relay under dash (silver one above ste ice port) lots of info on that in the CUCV info posts.
acmunro
Reynoldsville,PA
Hard to say from here, but I just had a CUCV that I purchased from GL with what looked like a brand new starter. The starter solenoid failed and burnt the fusible link. I replaced the solenoid and the link and it works great now. Good Luck
kadetklapp
Indiana
I had a '79 Scottsdale 3/4 4x4. I had the exact same problem (except mine was a gasser, so I don't know about the glow plug card) and I installed a new starter, new fusible links, and never was able to get that truck to turn over again. I ended up selling it because I was sick of dealing with it. I feel that had I spent more time with it and had access to a lift, I would have found a junked out ground somewhere. The truck was very rusty.
