dependable
- 187
- 63
- Tisbury, Massachusetts
A lot of threads about 6.2 heads lately, thought I'd add one. Am working on another low mileage M-1008, when I got it from GSA, it had what I thought was a bad lifter. After taking valve cover off and compression test, it turns out to be exhaust valve. 400 or better PSI three cylinders on that side, and one that would barely register. I have never seen one valve seat so bad on a otherwise low wear motor. I guess it could have had a bad spring, but spring seems OK. It did not eat a glow plug, seen and repaired that before, no dents in top of piston.
Am going to use an NOS head I bought, as this one looks too far gone to fix. I don't think there is any way a bad lifter could cause this, anyone think other wise? I would have to delay reassembly to get a new lifter. New head comes with new valves and springs, so they will be OK. Push rod and rocker arm look fine.
My guess would be some debris got stuck in valve, any other ideas of cause?
First picture shows the bad valve compared to a good valve, second is close up of badly pitted valve seat. It must have been run like this for a while. Fortunately, piston and cylinder wall look fine. Would probably have worn some if it was a gas motor.
