Busted Backing Plate for rear brakes
Red Dragon
Penobscot Maine
Busted Backing Plate for rear brakes. (With pics!)
Hi all, it's been way too long. I found some brake parts lying in my driveway, then found this-
I have a 1986 m1028. Anyone ever encounter this before? How hard a job to get a new backing plate installed? I have done most things myself on this truck but would hate to get halfway done and get stuck because I needed a special tool or something. I have done rear brakes before so I am familiar with brake shoes and wheel cylinders (probably need a new one) I Can't seem to find the part I need for the backing plate online. Also have no idea the part number for this, Can't find correct tm's. As always your help is greatly appreciated.
porkysplace
1,487
mid- michigan
Should be 4 nuts that hold the backing plate on the studs in the axle housing . Unless the threads got damaged somehow it should be straight forward bolt off / bolt on . Also the steel brake line could be a problem , but thats a easy replacement also.
Red Dragon
Penobscot Maine
Wow. Thanks! What a relief. I'm going to do both sides with new shoes and yes, brake line is busted But no big deal. Any idea where I could get the part number for the backing plate? Thank you very much for setting my mind at ease.
porkysplace
1,487
mid- michigan
The GM part number is in the parts TM any good parts house should be able to cross it to their part number.
Red Dragon
Penobscot Maine
Just tried to find this part-
Backing plate 14068905. Apparently it is no longer made. I was thinking of trying Hillbilly Wizard unless I'm missing something. Seems odd that no one makes this part for such a common axle.
Chaski
55
Burney/CA
Hillbilly wizard will have you covered, or your local self service wrecking yard. I had some in my side yard for years, but they went to scrap heaven.
Red Dragon
Penobscot Maine
Went over some of the tm's to familiarize myself and am dumbfounded at the amount of info on this site. Very nice. Now that I have a "smart" phone I will be viewing this info more regularly.
1,806
Hillbilly Wizard had a supply of NOS rears for a while. Many of them were converted to rear disc and at one point, he had a stash of brake parts. I bought a pair of NOS backing plates with everything attached. I'd say he would be my second stop after searching here. Many members have done the disc brake conversion.
Red Dragon
Penobscot Maine
Have a set of NOS rear shoes, wheel cylinder, and used backing plate coming from Hillbilly Wizard. I did not realize how much work it is to get the drums off. When I said I had experience with rear shoes it was on my ford ranger. Just a bit different. I will search the tm' s for tourqe specs. For the bearing retaining nut and axle bolts. Anyone know the number? I've scrolled through some 900 pages so far. Really great info! Thanks for the help.
Sent from my SAMSUNG-SM-J120A using Tapatalk
Chaski
55
Burney/CA
Is the drivers side toast? If so my sideyard has a present for you. I hadn't tossed it after all. You pay shipping and send me something random (but non perishable) you don't need valued at $20 or less.
Doh! Just realized that I found the backing plate about an hour late!
Red Dragon
Penobscot Maine
That's really cool but ordered one from Hillbilly wizard I shouldn't back out now but that is so nice of you. Thanks!
1,172
Please share this bible with us.
Red Dragon
Penobscot Maine
I can't afford a new axle so I need options. One of my thoughts was to install new backing plate and leave out brake components and cap off the brake line at junction block then I at least would have three wheels with working brakes. Also the bearings are toast in wheel hub.
cucvrus
10,039
Jonestown Pennsylvania
View attachment 668776View attachment 668777
I see nothing that a skilled welder could not repair in an hour or 2. That is all you need. Worse case scenario. Weld the backing plate to the axle. It will do the same thing and still be removable if the need be. But why would you need to? Don't fret take it to a weld shop. If you were closer I would enjoy the challenge. Good Luck. I have a friend in Maine. he always goes to Hedge Hog village to get things fixed. I don't know where that is but Frenchy is a good welder there.
