Buzzer noise
98G
Former SSG
4,271
You have a sensor that failed. They fail on. Replacing the failed sensor will resolve it.
Air pressure, or park brake.
There's not a simple way to disable just the buzzer. Putting tape over it is as close as you can get. Then there's the issue of if there was ever an accident they'd scream bloody murder that you 'disabled a critical safety system'.
dmetalmiki
2,027
London England
The sensors really do need checking asap. (As) failing on is as bad as failing off, either way you would not know the status of you air system.
