By chance does anyone know if NAPA sells an air brake light switch?
CMXterra
Minneapolis, MN
I saw that there was talk of a NAPA part number for the non air switch. But do they sell a switch that works with the air that is a replacement for the OE air switch?
1,172
Yes, I just searched the NAPA site for "air brake switch" and found this.
Part Number: MBI BE13240
Product Line: Midland Brake Products
Jeff Nelson
10
Queen Creek, Arizona
There is also switch we use on aircraft made by Hobbs. It's used to sense oil pressure, air pressure, fuel pressure, depending upon the model. It may not be a direct replacement but works fine. It's the style I will use on my rebuild for the air pressure alarm. If you're interested I'll find the info for you so we have a second source substitute.
Jeff Nelson
10
This is what I was suggesting as an alternative: Hobbs switch - TheFind Note that these are for an example only. The reasons my truck will be converted is that these are very commonly available and the right version is adjustable. In addition, mine will be doing double duty so the original won't work. I use them for low fuel pressure warning, low oil pressure, etc. The actual Hobbs switch (which is all I'll use) is very heavy duty, comes in many versions, and is reliable. Keep in mind that you usually get what you pay for...
DeucesWild11
12
Putnam County, NY
Saturn has them for $28.50.. not sure if they are lower quality then others but I have had good luck with their stuff.. They call it - Switch, Press. Stop light. on their website
