C Turbo
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
I mentioned Ken because when he rebuilds them he gets you flow charts and other cool things I am not smart enough to comprehend.
jwaller
19
Columbia, SC
Re: RE: C Turbo
houdel said:
jwaller said:
I can also rebuild and upgrade them with larger more efficient compressor wheels.
So does that mean more boost?
no. it means more efficient boost. as in cooler discharge temps.
more fuel = more boost. but the good thing about the upgraded turbo is you can run more fuel without getting the high egt bc the turbos making cooler air.
cooler in = cooler out.
ken
24
Houston Texas
I can rebuild you one i have here. A new one is avalable but ain't cheep. You can modify a C for more air flow. And it reallt helps the temps. There is a difference in CFM but you will see very little PSI change. You will notice that it will spool up quicker and give you more power at lower engine RPM"s And it will reduce black smoke along with reducing EGT's.
SuperJoe
Mesa, AZ
just a quick question. what do used non rebuilt C turbos go for? as in a straight take off. also the same question about D style
houdel
9
36
Chase, MI
They seem to go in the $100-$150 range for take-offs, IMHO.
Djfreema
Santa Clarita, Ca
I sold my almost new D turbo last summer in perfect condition for right around $100 on Ebay. Ken or Jwaller, do you guys have any modifications for a D turbo to get better air flow?
ken
24
Houston Texas
Dj, yes i can do the same mods to the "D" also. In stock form a "d" will move more air on the flow bench than a "C" will. I also polish and remove rough edges from the elbow at the intake manafold. The main reason is to remove turbulance. This will help keep the air cooler and let more in.
