Cab ground issue
Dead pilot
135
Fallbrook, CA
I'm back to working on M36 after some time off of it since I broke the dog bone after the brakes failed. Till I get the parts in for that repair I'm started back up in the cab and found that none of my gauges are working not even the horn. I have a new front harness installed and got a new circuit breaker when I installed the harness. The truck starts with no issues and the lights work. The horn button is the new style and the horn solenoid is new and works tested on my the M109. Am I missing some ground strap or something else for my gauges?
Sent from my SM-N975U1 using Tapatalk
cattlerepairman
3,307
NORTH (Canada)
The main ground strap is behind the battery box. There is another on the rear left of the multifuel engine block.
Maybe you have more than one issue. The gauges all ground via the four twist lock screws that hold the gauge panel in. Sometimes the rust and dirt interfere. The horn should have good ground through steering column and box...check that it actually has a working hot lead at the bottom end of the steering shaft.
Sent from my SM-G950W using Tapatalk
Dead pilot
135
Fallbrook, CA
Thanks for that. I am missing the grounding strap behind the battery box only have the one to engine block. When I put the cab back on I never had one there. I put new fasteners in and ran a ground wire from the cluster to cab.
Time to wire chase
