Cab Heater Fan electric modification
Plasa
322
Italy
Dear all!
Does someone know the power consuption of the cab ventilation fan? It's the classical fan without AC, I want to try to get it working with a PWM control instead of the on 1-2-3 switch...
Thanks!
Christian
Plasa
322
Italy
For now I want only control the speed of the fan. In my eyes the pos. 1 is too fast and makes lot of noise. But your idea is great! Maybe I change also the valve on the coolant line!
My idea was also to add 2 small fan's for the 2 lines to the feet. to heat more the bottom part of the cab.
Thank you!
Christian
Are you trying to set up an automatic temp control? I installed an electronic servo on the coolant line if that is of any use to you. I bought the whole kit but you can buy just the valve if you are making your own controls.
Plasa
322
Italy
Just an update: I tried to change the switch with a step-less PWM electronic module. Forget it, the motor is much louder than with the original switch with the 2 resistances.
So after 3 hours of work I was at the same point that at the beginning... :-(
Christian
Plasa
322
Italy
Definitly! In low speed the motor buzz so loud that I decide to put the old switch in again.
Yea these are brushed motors. If I recall correctly i thought PWM was a better match with brushless DC motors…
Plasa
322
Italy
Maybe.. but for now I leave it as is because switch and motor are working, and I don't like change a running system... :)
DieselAddict
2,058
Efland, NC
I've had that issue with brushed DC motors and PWM speed controls. What I did was use a H-Bridge and a cheap microcontroller to build a PWM controller. This gave me control over the carrier frequency. I was able to choose a higher frequency that was inaudible.
Just a thought if you really want to have the feature.
Plasa
322
Italy
Thank you for the tip.
Maybe with a higher frequency can solve the problem. For now I let is as is and I will think when or switch or motor fail...
Thank you again!
Christian
