IMA944T
- 0
- 0
- OKLAHOMA CITY
Purchased new cab heater and want to know about the heater hose hook ups. Water pump has outlet that appears to be 3/4 npt and the manifold has couple of 1/2 npt as does the coolant housing at the frt. end of the manifold. The coolant sensor appears to be threaded into this housing on the frt. end of the manifold. Is there a specific place for the two heater hoses to be hooked to? I have the two threaded valves for the hoses to hook to. One is 1/2 npt and the other is 3/8 npt. Anybody have any pic's of these hoses hooked up properly.
Also would like to know about the heater fan motor. My switch for it is a two position switch. I would think that if hooked up it would have the motor running WFO. Would like to know about making the fan have a high and low speed or poss. even variable speed. Heard these heaters work great.
Also looking for the 90 degree bend that bolts to the firewall inside the cab for the duct work. Anybody out there have one they want to part with ??? If you have a extra one Email me at BUDDO2003@YAHOO.COM
