lawdog1623
- 1
- 0
- Texas
Well ive hit the first wall in my restoration. I was replacing the doors and i found a bad rust area on the driver side under the dash. It seems that the rust is caused by water running into he crack between the windshield frame and the front cowl. The cowl has a tin patch that i found when i removed the carc. It looks like they half a**ed it the first time and now it needs to b replaced or spliced. I pulled the dash and it appears that i need to either splice in the driver side of the hood cowling or completely replace the entire piece of metal. I also need to replace the vertical wall of the cab cover (the piece with the rear window) because the bottom rail that bolts to the cab is rusted out. The top is fine. I plan on taking the truck to a body shop and having them do the metal work and ill finish it out. Most of the guys i know are ignoring this on their trucks but i want it fixed. Has anyone on this forum had this issue. Can someone suggest where to find the cowl and the back of the cab cover? Any suggestions are appreciated.
