csoledade
- 0
- 0
- Nederland, CO
Tried searching first and did not find the information.
The TM says:
"Cab height when raised is higher than normal. Ensure area above andin front of cab is adequate before raising cab. Failure to comply mayresult in damage to equipment."
Does anyone know how much clearance you need to tilt the cab successfully on a M1078? How much longer the vehicle becomes with the cab tilted? I am trying to ensure my steel building workspace will allow the cab to be tilted indoors.
Thank you!
The TM says:
Thank you!
