Cab Tilt Cylinder
Keith Knight
2,057
Wauchula, FL
My cylinder decided to start leaking like a sieve.
Is it rebuildable or buy new?
Also has any replace one and can share there experience?
Doing the replacement with the cab up sounds easier but not safe.
GeneralDisorder
5,742
Portland, OR
You NEED this kit anyway. For your roof rack weight, etc. This is the upgraded cylinder with cab floor reinforcing since the sheet metal where the ram attaches to the cab floor is like wet toilet paper. Mine was already bent and I had to porta-power it straight to get the reinforcing plates installed and I just have a HIMARS hatch on my truck.
You replace it with the cab half-up using the cab support brace special tool from the FMTV service tools kit (I carry one of these onboard). Disconnect it from the frame side, use the controls to pull it back in, and then remove the cab side bolt and hardware. You will have to move the cab cam-link over to the new cylinder and they are on there with thread locker so I had to use heat.
Keith Knight
2,057
Wauchula, FL
Is this kit bolt on using existing holes or is there drilling involved?
Do you need access to the interior of the cab during installation? Door open with cab tilted?
GeneralDisorder
5,742
Portland, OR
The cylinder is bolt on. The reinforcement kit uses self tapping sheet metal screws and it's all done from underneath.
Except - in my case the cab sheet metal was already starting to wrinkle and deflect and I had to use a porta-power and some massaging from above - drilled a hole in the floor in front of the passenger seat to use a brass punch on some of the pushed-in sheet metal. I'll find my pics here in a bit.
I haven't got to installing the forward plates yet. The damage from the air pump bouncing the cab as it lifts was all on that rearward outer bracket and the floor where it's spot welded that was really being fornicated.
The forces involved are doing this to the sheet metal and the air operated pump action causes the cab to bounce and any additional cab weight in it is being hammered into this wimpy sheet metal mounting point. The Steyr cab was designed to be a lightweight balanced manual tilt not to be lifted with a ram like this. Especially not with the armor they started adding with the LSAC, and the field expedient armor being added by troops. It just broke them. I guess engineering didn't think that through very well.
My truck never had a weapons system or anything so IDK if the troops loaded her up and that caused it or what. The HIMARS hatch is aluminum and probably 150-175 lbs or so..... Can't be more than a roof rack full of boxes of gear though and certainly isn't more than the roof can support based on the stencils for weight they used above the doors. So IDK. But the kit is well worth getting while they are available. They were $225 a minute ago but now that I have told a bunch of people the demand went up and the prices have followed.
