Cable uses
Leonardo82nd
70
Edinburg Texas
The 2nd one is 60 amp 3phase 208v.
You have 3 legs of 120v, one neutral, and one ground.
The 120v legs are 120v single phase to Neutral. They're 208v to each other.
Some of the drash type gensets have the female version of that, and some of the PD boxes have input as well as output ports compatible with it.
Thank you
  • Like
Reactions: 98G
98G
Former SSG
4,271
First one, the four small pins are the ground wires, four big ones are the three phases and the neutral. I have a cable like that without the connectors. Main wires were 1 ga, four smaller ground wires were each 8 ga. YMMV.
And I believe, although I'm not certain, that it's rated 100 amps sustained load.
