- 5,777
- 3,215
- 113
- Metairie/La (N'awlins)
I have some black Camian steel wheels with runflats & goodyears on my 5 ton m923. They were brand new and surplused in the GL days at Ft. Polk. I went to air /check them and some were in need of air. I found it a bear to hold the air chuck against the stems and to get air pressure readings off my gauge since they are slightly larger than normal. The threads and stem diameter is not the normal size "regular" thread nor are they the large bore stems as they are smaller than that. I also don't like that I can't cap them off.
What size thread are those and does any of the tire hardware vendors make adapters to use with regular size fittings or extensions and caps with that special size?
