Calling all bobbed experts
Satchimo
Bigfork, Montana
Ok, so after attempting to find any info on a bobbed 135/211, I have found nothing more than a couple pictures of one on a flatbed. I have a 52 m211 with a small block swap and 2 speed t-case. I have been throwing around the idea of bobbing it but I have some questions I cannot find answers too and would appreciate any and all info/thoughts.
1. Is this at all even considerable without power steering? I will want to run 16.00 xl's or similar.
2. Can the rear hubs be flipped on banjo axles or will I have to go with a custom backspace wheel?
3. Are there any ideas as to why this has not really been done?
Keep in mind that this truck is nowhere near original, and would cost me way more than it is worth to get it back to a real m211. However, I do not mind spending some cash to have something off the wall different.
Thanks in advance to everyone. :)
-Scott
2,459
It's impossible to bob an M211...it's even in the manual. In fact, if someone has replaced the 302 gasser and the hydro, you have to turn it in as an abortion.
PM me for the address to ship it to...at your expense of course.:roll:
Ride2Kill
Englewood, Colorado
I say go for it as well. It would be cool to see something different. I don't see any reason it would be any more work than bobbing an M35. The only thing I'm not sure about it the flipping of the rear hubs. With that small block it would be super easy/cheep to mount a power steering pump. A plus if you wanted to do the fab work for mounting a steering box.
spicergear
26
Millerstown, PA
Do it! Hang a spring set in the rear, drop the rear most driveshaft and see what you can do. You could...always...ditch the stock rears and put a set of later Rockwells under it and plop in a NP205 behind the small block dealie that's already in there. Then you have no worries on hubs, T-case rotation, etc.
135gmc
St Paul/MN
The rear hubs can be flipped very easily - look at the TM for the details, and you'll see it will only take a few hours. You would probably want power steering if you change the tires, but there's lots of room, and standard GMC truck steering parts would probably be the easiest to work with. You might find it to be very underpowered with the stock engine, though.
rainbow
horton kansas
The rear hubs can be flipped but you have to have a different brake dum adaptor,like the ones on the front axel. Much eaiser to put hubs and drums off 135 axels. Ihave messed wilth m211s and m35s for years. I have used a gmc pretty hard. They are a toughfer truck than the m35. gmcs have stronger frames, twice as much rear springs, much better brakes, larger diameter drive axels, recirculating ball steering box turn eaiser, torsion rods on front axel,much eaiser to get parts for at local auto parts, list goes on and on
Satchimo
Bigfork, Montana
Thanks for the support and info everyone! This will be an ongoing project over the winter/spring, and will hopefully be back on the road come summer. I have a very talented circle of friends, so the fab work should not be a problem, just needed to know what you all have answered for me.
I will include some pics of our platform, we like to call him Norman. :)
It is a semi built 400 sb, which may get swapped for a diesel, but that will come much later.
