Camo paint
86k10
Bertrand, Nebraska
Where does one find the green or what I would call the base color. Have some spots to touch up and figured you guys knew how to get some or something close.
emmado22
147
Mid Hudson Valley NY
CARC paint is no more toxic than any other paint. Take normal propper precautions when applying it, you wont have any problems.
gasser
Ocean Springs, MS
Um - I wonder if I could shoot CARC with my airless sprayer? I do have a tip for Exterior latex house paint ... you think that's sufficient? Or would I need to go a gravity feed system (like most Auto paint sprayers).
-graham
Jones
Sacramento, California
CARC data sheets are in the tech bulletins section of the SS library. All kinds of info including what size tip to use and what pressures to apply at. Treat it like any other epoxy coating-- avoid the fumes and spray mist. HVLP is best but we bought a "throw away" rig because clean-up's a pain once it kicks off.
The biggest concern/danger from CARC is sanding or sawing through the finish which releases CARC dust that is loaded with all kinds of heavy minerals... Silica, quartz, talc, christobolite, chromium oxide, and green spinel to name just a few.
Alfa Heaven is a good source for the late one-part CARC.
poppop
39
Brooklet, Ga
If you touch up carc with gillispe you will be able to see the spots. We touched up spots on a freshly painted truck and you can still tell the difference. The gillispe is smoother and shiner.
