The M101A2 wheels are the same as the pickup-based CUCVs, but not the M1009. The M1009 is 6 lug, the rest are 8 lug.Also, the M101A2 has wheels that, I believe, have the same bolt pattern as your CUCV, but you might need to check that point.
Arlyn
Beat me to it. You can pick up a set of adapters for <$200 bucks to put on the trailer, then you could use all the same wheels/tires (after a 4" lift to level out the trailer to the hitch) That's my plan. (until I swap to dana 60/14bolt)The M101A2 wheels are the same as the pickup-based CUCVs, but not the M1009. The M1009 is 6 lug, the rest are 8 lug.
