Gunfreak25
- 620
- 113
- Yuma, AZ
So now I have my first electrical question. And yes, I have used the SEARCH button to death first!
My M211 is the Korean era deuce. The truck is your standard 24V early style electrical system. However, my truck has had the original 302 gas I6 pulled and a 455 Olds V8 put in place. The truck was never quite "finished" and currently nothing electrical on the truck works aside from the ignition which is obviously 12 volt. So now, I have a 12 volt ignition while the rest of the truck is still setup for 24 volt with almost all the original 24V 14 gauge wiring in place. It currently just has one 12V battery for the ignition.
My goal is to add a second battery for 24V power and keep everything on the truck stock 24V aside from the ignition which will obviously be 12V. Here's where I can't make a decision. Should I just tap off of one battery for the ignition OR install a 24v to 12v converter for it? I am assuming tapping off a single battery is a bad idea and will shorten the battery life significantly?
My main question however, is the gauges. They are the original 24volt gauges and I really want to use them. But, how in the heck can I use the stock 24V gauges with the sending units on the 455? The only electrical sending units I can find are for powering idiot lights, NOT gauges. Am I going to have to replace them with aftermarket 12V gauges?
Heck, if I could i'd like to just convert the entire truck to 12V. I guess it's already halfway there. My main concern is the wiring, 12V puts out significantly more amperage than 24V and I am afraid of frying something. What will be the easiest/cheapest method for me to get everything working properly and safely?
And if you couldn't already tell, my knowledge of electrical components is still pretty slim. I am learning more stuff everyday though!![Very Happy :grin: :grin:](https://www.steelsoldiers.com/images/smilies/icon_biggrin.gif)
