Geez after reading a bunch of posts on runaway diesels Am I getting in too deep here?
I've been driving tractor trailers for about 20 years and frankly I've never heard of a diesel running away. Guess I live a sheltered life
Is a runaway more prone to the Detroit or is it universal with these MV's?
I'm not sure what you're referencing when you say runaway, but I'll chime in with what I know. The M35A3 does not have a "Park" in it's automatic like a car or truck, and it is manual so you cannot shut it down in 1st or Reverse, let out the clutch, and use the tranny to "lock er down" like most manuals. You rely on an emergency brake, called a parking brake in the tech manual.
If not on level ground, and the parking brake is not adjusted out properly in accordance with the tech manual, ie. run engine up to 2000rpms and adjust brake adjustment on top of handle, then the truck is subject to rolling away, especially if you are not familiar with proper procedure, or just negligent, and you don't chock up the tires properly.
Yes, the M35A3 can run away in this manner, especially with engine running and it not locked down properly. But if you follow proper procedures, have your vehicle parking brake adjusted appropriately, there are no problems.
If this is what you're referring to by chance, then no, you are not in over your head. Just read the operators manual on the M35A3 and follow procedure.
edit: just read Patracys post. I guess I don't know what a runaway is. Please explain the detail of what happens with a runaway. Thanks in advance.
BTW, the post above was written because I just saw a Deuce today that ran away from its owner because of the text written above. It came within a foot or two of clobbering a big oak tree. Ran away from him about 75 feet.
