realm
- 5
- 0
- Memphis/TN
So I've read 50 million threads on here about recommended tire sizes and the axle strength, etc.
General concensus seems to be 33x12.50 is max recommended for M1009.
However, what is the weak point of a diff when they talk about this? Is it actually going to snap and break, or is it the inside gears that fail or what? If inside then couldn't you just replace it with a stronger ring and pinion gear?
Where I'm confused, is how do I see little Toyota's running around with these puny looking axles and yet running 36" tires all day long? Some of them I know are stock axles.
Are the Blazer 10-bolt's really that weak even compared to a little Toyota?
With that said, I love Toyotas... had a Tacoma with 33's I beat the crud out of and it never quit.
I'm just confused because for my use around the farm and city the Tacoma with 33's never failed me, so I'm wondering if I can do the same with cucv and 35's, or if the axles are really that much weaker.
Thank you.
Thank you.
