daschae
- 0
- 1
- Chandler, AZ
M923A2 I just picked up will run with vigorous pumping of the transfer pump and ether while cranking. Will stay running no problem for as long as I want, even idle. If I shut it off and immediately try to restart it, it will crank and not fire at all, not even a little, same is true if I wait overnight. Fuel lines from tank to pump are good, new rubber. I sucked fuel up to the inline filter, and pinched the line with vice grips, waited a few minutes, then released them and fuel was still in the line, I could hear it running back into the tank, so Im confident the leak isnt between the tank and pump.
So here is whats confusing me, can the cummins run if you get it going with a bad lift pump? Does the IP create suction that would keep pulling fuel from the tank?
Also, even when I am pumping the **** out of the primer, it doesnt create hardly any (if any) suction. I put my finger over the fuel supply inlet and it doesnt even suck enough to pull my skin.
Any thoughts on this?
