Can the fuel primer pump from a C7 be used for a 3116?
Reworked LMTV
Expedition Campers Limited, LLC
1,566
1,214
TN
Can the fuel primer pump from a C7 be used for a 3116 with the appropriate adapters to the fuel lines?
Reworked LMTV
1,566
1,214
TN
Shouldn’t be different. The filter boss is 3/8” NPT, with 3/8-JIC6 male adapters. The fuel lines all have JIC-6 female ends…
I don't know if you can see it in this pictures, but fitting from original primer pump is smaller that the new one. Maybe wrong primer part installed or variant?
They are the same. I've pulled fuel primer pumps from donor engines for other FMTVs of all years.
Puzzler... I put the old fitting next to the new primer in the pictures. The old fitting is small enough that it can just slide in. The part uses a washer / rubber O ring. I guess I can just order the larger JIC 6 to 3/8", but what about the washer/ O ring? What is the official name of that?
hike
—realizing each day
918
Texas Hill Country
I ran into this when replacing our primer pump last spring, and forgot to mention last night! oops!
The military version used a 3/8 orb fitting which is 9/16-18 thread with the o-ring. The only place I found the mil-spec version required bulk orders. The commercial version available today onesey-twosey uses a 3/8 NPTF which is 11/16-18 thread as @Ronmar noted. You need new fittings between the boss and fuel lines to replace the male orb side with a male 3/8 NPTF. The NPTF fitting is tapered pipe, no washer or o-ring; just a little pipe dope.
Here is my final response to Rancor last spring which they confirmed:
So, dumb as a bump on a log.
The pump I am replacing has 3/8 orb fittings,( 9/16-18 ); though the 445R has 3/8 nptf fittings, ( 11/16-18 inch ).
Please confirm. No o-ring, Pipe sealant.
I can do that—
New fittings and pipe dope. She works and doesn't leak—
