ramdough
- 1,729
- 113
- Austin, Texas
Looking to reduce the overall height of the transmission cooler in support a camper conversion. The fan motor sticks up pretty high. If I unbolted the the unit from the cross brackets and flipped it over, is there any issue? I would gain some space to blow the air..... otherwise the fan will be right up against the box.... blocking air flow.
The other option is to space the cooler down, but I thing the center location of the fan may be better upside down (see below).
Also, I would like to slide it right up against the transfer case if I can, but am worried about the heat from the muffler. Does anyone know which direction the cooler blows? Mine is disconnected and I need to lengthen the harness to make it work (part of my winch swap caused this)..... probably will wait until the cooler is moved to correct this issue.
Your help is greatly appreciated!
