Can the turn signal connector be re-wired?
JCKnife
46
Kentucky
M35A2 turn signal connector, I have 2 but both in pretty rough shape. Can they be disassembled and re-wired? I don’t see how...
sue
344
tulsa OK
Take it down to the local airport and
find out who does avionics installations
and offer them a case of beer and see
if you get any takers. It’s a very
common aviation part.
gimpyrobb
dumpsterlandingfromorbit!
27,785
750
Cincy Ohio
Jo, I have a kit for wires you can use. Should have the tools to take it apart if you want. Or I could just send the tools
gringeltaube
Staff Member
2,492
Montevideo/Uruguay
Sounds like a “no” for most people then.
... but it's definitely a "YES" for someone capable of rebuilding his winches...;-)
Probably easiest if you had those special tools, although it can be done without them. You just need a soldering iron, tiny screwdriver, needle-nose pliers, some silicone grease and lots of patience...
JCKnife
46
Kentucky
Thanks guys. Let me figure out if the wires are the problem first. My interior turn signal indicator light has quit working, but the bulb is good. I'm thinking maybe it's the solid-state flasher inside the fender?
JCKnife
46
Kentucky
Seen in that thread: "I was wrong. It wasn't the blinkers not blinking, it was the indicator light on the turn signal switch not illuminating when the blinkers were on. Poor grounding of the switch to the column."
Does the turn signal device need to be grounded to the steering column? I didn't think that was possible because one of mine is made entirely of plastic...If it does, that may be my problem, with fresh paint on the steering column...
EDIT: Yep, I have only a bad ground. Confirmed by holding a wire from the turn signal hose clamp to the floor. Still has me scratching my head wondering how the all-plastic unit is EVER grounded... but problem solved for now.
TOBASH
3,461
Brooklyn, NY
Why not check each wire and see if OK. A little dielectric grease and a nail to scratch the inside of each contact to expose metal might be all you need.
Then use male and female Packard connectors to terminate the wires and allow re-attachment to the vehicle.
Don't forget to clearly number each wire, as the metal number crimps are going to need to be removed to install Packard connectors.
IMHO.
