zcamarokid
- 0
- 1
- Allendale, MI
I am trying to change my motor mounts, but I am having no luck removing them. I took the 3 bolts that hold the mount to the engine bracket. I also took the bolt out that runs through the engine bracket and the mount. I removed these 4 bolts on both sides of the engine. I placed a jack with a 2x4 under the oil pan to jack the motor off of the mounts, but it raises the entire front end. I do not see any other bolts that are holding the mounts to the engine and frame.
I also removed the 2 trans mount bolts thinking this would remove the possibility of binding on the drive line. Any insight would be greatly appreciated.
