Can't find Alt that fits
MerkWork
INDIANA
Okay, I think both alts. are bad and none of the local shops can find the right alt for my cucv. Is there a specific type or does someone have a part # that can help. I need them both unless I figure out how to convert to a 12v system. I have one prospect coming in tomorrow but they want 209.99 for the darn thing. Ouch!
1,172
Rebuild them.
Use the search funtion on the left side of the page
Every issue you can have with alternators, has been covered.
Read for a few hours, the threads in the CUCV forum.
New is gonna cost ya, rebuilding is easy and should cost you about $75 to do both(yourself).
markg
hutto,tx
if you need one in a pinch go to the zone and get one for a 75 cadillac. same case size.
i have a whole pile of ones i thought were bad, would not work on the pass. side, but would on the drivers side. get them tested.
kassim503
Stony Brook, NY
The drivers side alt is a 15 si Delco alternator, which is also compatible with the 12 and 17 si series alternator that is found in almost every GM car from 1970 until the mid 80's.
Could always give rebuilding them a try, they are really simple devices. The kind of thing you can take apart and put back together with no manuals or instructions
1,172
the drivers side alt is a 15 si delco alternator,
wrong They are 27si alts.
Doug, is that wilson number for an isolated ground alt?
Warthog
229
OKC, OK
That NAPA number is for an "isolated ground" Wilson rebuild. Covered in the CUCV Wiki. WIL 90014277
There has been issues with these alternators. Some have been rebuilt without the "isolated ground". Make sure you check them before leaving the store.
MerkWork
INDIANA
I am thinking of going the rebuild way...the wilson was going to run me 209.00...way too much for my budget!
Thanks fellas for the info big help!
1,172
no problem/np
190
Albuquerque NM
How do you test a Wilson rebuild to determine if it is an isolated ground? Thanks.
With a volt/ohm meter, test for continuity between the output terminals and the alternator case (shouldn't be any on an isolated ground alt). I like to test ALL the alternator terminals on rebuilds to make sure nothing is shorted to the case.
Hoolio
Painesville Ohio
Find a local starter/alternator rebuilder..They can rebuild/repair your old units..They're 12 volt units with external grounds..I had both or mine gone thru with new bearings for about 60 bucks apiece.. I use Buckeye Auto Electric in Painesville , Ohio
Friar Mycgyver
Atlanta Georgia
Just posted part numbers for rebuild kit for a 27 SI. You can search my posts Yo get all the info you need. Rebuilding them is super easy. Kits are about $27 plus shipping.
